Tensioning Serpentine Belt (No Tensioner)
So I've determined that my belt needs adjusting (get a screech on startup when its cold). Spec for the belt is 10mm of deflection with 10 KG of force and I can quite easily push it further than that by hand. Anyway, this is a CF4 Accord that has no tensioner. It only has A/C and Alternator, and it seems that the alternator has some form of adjustment, but not like I'm used to. One side of its mount is the usual bolt-based pivot, but the other has some kind of jack screw setup. Not sure what I need to loosen and what I need to turn to adjust the tension.
Anyone got any experience with this?
Well, the screech isn't the belt. Got someone else to start it with ears on engine and it comes from the clutch area. My guess is pilot/throwout bearing, yay. Weird it only ever does it on cold startup, never once the engines warm.
Sounds like you were right on the money on the starter. The screech will 'move' depending on when I release the key. If i let it go early the noise happens just as the engine comes to life, little late and its well after it starts.
Anyone know if the starters are a pig to get out?
Take the two bolts off the slave cylinder.....on the left side of the slave cylinder...on the ball piece side..put some multi grease on it. Put it back on. See if the sound goes away.
Noise is the same no matter where the clutch is. It always happens after I let the key out. (If I ride the key after the engine starts briefly, it won't happen until I release the key). So pretty sure its the starter.
Fo-Do Fanatic
Apr 7, 2010 03:59 AM
jt1583
Nov 22, 2005 03:49 PM
