Can anyone recommend me a good tuneup kit?
I don't really know what good brands for tuneup kits n what not. I just don't want to buy a tune up kit n turns out to be a bad one
Would like someone to recommend me a tuneup kit with or without the timing belt n whatever belts it usually comes with
I don't care if the belts come with or without, if not much difference I'd like one with so that later down the road I can have a shop replace my timing belt n water pump
My car's a 99 ex civic
did not know they have tuneup kits. But I would recommend all OEM parts from honda, if you feel like being cheap, get the autozone stuff. but Oem is best. the only place I see kits are on ebay.
To me a "tune up" meand wires, rotor, cap, plugs.
Usually done along with an oil change.
Then there is filter servicing
And major service, Timing belt, water pump all new accy belts.
All of these have different intervals
As for parts:
plugs- the proper NGK
Wires- Bosch Red Wires from Auto Zone
(rotor and cap as well)
FIlters -WIX
Fluids- HONDA (except oil-I use Mobil 1)
Timing Belt Kit - GATES
These are my choices. I maintain 4 Hondas ( Pilot CRVx2 and a Del Sol)
Also read the Sticky on buying quality aftermarket parts
As for parts:
FIlters -WIX
Amazon and Ebay sell them, but it is unknown if the parts are the right ones or of decent quality.
Piece it together like others have said.
My recommendations are...
NGK Plug and wires (OR Beck/Arnley Wires)
Beck/Arnley Dist. Cap, Rotor, PCV Valve
Wix Oil, air and fuel filter,
And Contitech Timing Belt Kit
This is if you don't want to go and buy OEM parts.
Don't forget to adjust your valves and replace you valve cover gasket/spark plug tube seals/grommets as well (Beck/ Arnley).
MY qualification (as if is means anything): ASE Passenger Car Parts Specialist
for tune up, i usually get the ngk/denso spark plugs, ngk wires, fuel and air filter (if needed) from monument car parts. then get the oem honda distributor cap, rotor and oil filter from local honda/acura dealership. then take a trip down to walmart to get you some mobil 1 oil.
Read this and build your own: https://honda-tech.com/forums/showthread.php?t=3114911
bought:
Fuel Filter - 16010-S01-A32
Distributor Cap - 30102-P54-006
Distributor Rotor - 30103-P08-003
all oem from honda, bout $45 bucks total,
can anyone lookup the website n find me a 99 ex timing belt n water pump? they have it on the website but it doesnt specifiy which engine the timing belt will work on, and if i remember correctly some engines use different timing belts
idk waht else to buy or even search up from the sticky'd linked website, hard to search it up when idk what to search lol
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-96-00-honda-civic-tune-up-fuel-filter-2872418/
http://www.ebay.com/itm/1996-1997-19...4d502e&vxp=mtr
$87.50 shipped
PARTS LIST
DISTRIBUTOR CAP (oem#30102-P54-006 )
DISTRIBUTOR ROTOR (oem #30103-P08-003)
SPARK PLUGS X 4 (oem # 98079-5514G)
IGNITION WIRES (oem # 32700-P2F-A01)
OIL FILTER (oem # 15400-PLM-A02)
DRAIN PLUG WASHER (oem# 94109-14000)
http://www.ebay.com/itm/HONDA-GENUIN...item4ab52c6dbf
$208 shipped
PARTS LIST
TIMING BELT (oem # 14400-P2F-A01)
WATER PUMP (oem #19200-P2A-A01)
ALTERNATOR BELT (oem # 31110-P2A-004)
A/C COMPRESSOR BELT (oem # 38920-P2A-003)
P/S PUMP BELT (oem # 56992-P2A-003)
CAMSHAFT OIL SEAL (oem # 91213-P2F-A01)
CRANK OIL SEAL (oem # 91212-P2F-A01)
TIMING BELT TENSIONER (oem#14520-P2A-306)
$87.50 shipped
PARTS LIST
$208 shipped
PARTS LIST
@qbove in my eyes
I feel it's better replacing things before they go out
Well at least when I just bought the car, I'd like to replace as much maintainance parts as I can
Can someone link me to all the belts and water pump for my car
On that website? If someone's willing to go take a look please? Lol tryna do my car right!
