household welder
Old Jan 18, 2013 | 04:02 PM
millz's Avatar
Default household welder
Question, whats the difference between just a 140v welder and gas tanked? would a gasless work just as good as a gased welder?, i cant really get a answer from reading the FAQ
Old Jan 19, 2013 | 06:04 PM
SovXietday's Avatar
Default Re: household welder
Flux core welding uses a coated wire that spatters very heavily when it is welded. It is often very unsightly in the car world and you have to grind off all of the spatter. It's a real mess.
With a gas mix you can get rid of the coated wire and use a standard MIG wire. It will produce much nicer welds with a lot less spatter.
Gas is a little bit more expensive up front, but worth it in the end.
Old Jan 21, 2013 | 06:02 AM
millz's Avatar
now i also head that gas mix has a stronger hold that flux core
Old Jan 21, 2013 | 06:23 AM
spAdam's Avatar
Loved
Community Favorite
It takes a little more experience to get a good weld with the flux core, imo. Hence the reputation for gas being stronger. There are plenty of guys out there getting perfectly good penetration with flux wire though, it's just not as pretty.
Unless you're welding outdoors where wind is an issue, do yourself a favor and go gas. It's well worth the investment. The good news is that you can convert most wire feed welders to MIG with a simple kit.
Old Jan 21, 2013 | 10:43 AM
millz's Avatar
well my area of work is under my house, my garage is under my room connected to the basement, but it a way separated, how big of a gas tank would i need for automotive work?
Old Jan 21, 2013 | 03:21 PM
spAdam's Avatar
Loved
Community Favorite
If you're just noodling around at home a 20lb bottle is fine. I just exchanged mine today for $30
that-guy
Welding / Fabrication
12
Mar 23, 2011 09:48 AM
projectTeG
Aug 26, 2008 10:04 AM
kuja396
Mar 13, 2008 02:40 PM
Luserkid
May 27, 2005 04:29 PM
lewdude
14
Jan 26, 2005 06:05 PM
