gsr spark plug wires
okay guys, need some opinions. .. right now my car is running msd wires, with pretty much a full msd ignition besides the distributor itself. havent changed the wires in forever( at least 15000 miles, i got the car used about 5 years ago with the wires.. and yes, i dont drive it much.).
so what wires should i run that for sure you know are worth the price? also, sticking with NGK vpower plugs but if you know a proven better plug lmk thanks!!
OEM are the best honestly, unless maybe you've got a really extreme turbo build. I use OEM NGK plugs in my GS-R (although I think they are cheaper OTS) and Vpower's in my LS.
Edit: and I mean OEM wires are best
oem sumitomo or ngk are generally the preferred. ngks are a bit cheaper at 50 a set and have an excellent service life. i have seen sets with over 100k and no spark leakage or resistance change.
some guys are hard on the oem everything band wagon..which i can kind of relate to
but quality brands like ngk or more or less a true oem replacement sort of like an exedy clutch is an oem replacement for the fuji carbon clutch your car came with
ted
Apr 8, 2005 02:16 PM
