2000 Accord wipers only work on low
Old Jan 18, 2013 | 05:43 AM
ldutton's Avatar
Default 2000 Accord wipers only work on low
My daughters 2000 Accord wipers work on the low setting but quit working on intermediate and high settings. When you switch to those positions the wipers park where they are, but will resume when you turn it back to low. When I turn the wipers off they do return to the proper position. The windshield washers work.(FYI)
How can I test to see if it is a relay , wiper switch or control module ? Any ideas and suggestions appreciated.
Old Jan 19, 2013 | 10:15 PM
MasterChef1985's Avatar
Default Re: 2000 Accord wipers only work on low
it might be between the wiper switch or wiper motor. maybe the motor is dying
Old Jan 20, 2013 | 11:02 AM
jdowen2's Avatar
remove dashboard lower cover and steering column covers. Disconnect connectors from the wiper/washer switch. Remove 2 screws then pull out switch. Test 8 pin connector for continuity. switch is configured left to right , top row: A1 A2 A3 A4, bottom row : A5 / A7 A8. Test continuity in Off position A3-A5, Int A2-A7 and A3-A5, Lo A3-A8, Hi A4-A8. If you have good continuity between pin connectors the switch is good and odds are the motor is bad.
Old Jan 25, 2013 | 02:48 AM
ldutton's Avatar
Thank you for the info ... I'll test it and see how it goes and will follow up with results
NRMEUV1
Apr 8, 2012 03:29 PM
Catera
Dec 22, 2007 10:24 AM
ferio 95
Mar 3, 2005 04:47 AM
