Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
has anyone installed an oil cooler ?
Old Jan 17, 2013 | 08:50 PM
killaxkev92288's Avatar
Default has anyone installed an oil cooler ?
I was wondering who has done it and what kits you used. Maybe some pictures also if thats possible on where its installed and how it looks.
thanks
Old Jan 18, 2013 | 08:50 PM
Default Re: has anyone installed an oil cooler ?
no one has any information ?
Old Jan 18, 2013 | 09:53 PM
toyomatt84's Avatar
Sanji
I can't think of a reason why you'd actually need one.
Old Jan 22, 2013 | 06:11 PM
The reason im looking in to it is because i live in the desert. i have gone through 2 head gaskets and i want to try to do what i can to keep my engine as cool as i can so i dont stress my engine or go through another head gasket.
Old Jan 22, 2013 | 07:03 PM
toyomatt84's Avatar
Sanji
Definitely look into replacing the radiator with something aftermarket. Mishimoto makes an all aluminum drop-in radiator for the 01-05 Civics, which would greatly improve your car's cooling capacity (you could combine this with an aftermarket set of fans that provide more air flow, as well). Also, running a thermostat that has a lower operating temp, will force coolant into the radiator sooner.
Here's the Mishimoto: http://www.mishimoto.com/mishimoto-h...tor-01-05.html
As for an oil cooler, it can be done... but I do not know how to plumb one on a D17.
Old Jan 22, 2013 | 09:00 PM
thanks.. i have also been looking in to an aftermarket radiator. do you like the full size radiators or the smaller ones better? As for putting the oil cooler on isnt a problem. They do have some cool kits that are very easy to install. I was only wondering who has done it and how they like it. Maybe the radiator and all you listed will do the job.
Old Jan 22, 2013 | 09:05 PM
Oil Cooler Link
here is a link to a kit simillar to all the ones i have seen for it. very easy to install.
Old Jan 22, 2013 | 10:35 PM
doood's Avatar
been there done that
i dont think an oil cooler is going to help with your headgasket issues. you have other problems you need to address.
before you say anything, i lived in the desert for 4 years where temps regularly saw 120+ and my car never overheated with the stock cooling system.
Old Jan 23, 2013 | 04:05 AM
toyomatt84's Avatar
Sanji
I would definitely go with a full-size radiator, to be honest. You get better heat dispersion on the larger radiators.
Old Jan 23, 2013 | 05:22 AM
No I know the oil temp has nothing to do with the head gasket. I just wanted to do what I could to lower temps in the motor. But you're right thanks.
Old Jan 23, 2013 | 05:23 AM
Great. I will order one after i get my tax refund lol. Thanks.
Old Jan 23, 2013 | 05:28 AM
TheShodan's Avatar
Moderator
Head to the forced induction section and the Track/roadrace section. There are about 2 threads already done on oil cooler setups and what to put together.Its better than that kit that w as linked above, that's for sure.
Old Jan 23, 2013 | 10:01 AM
Great. Thanks for the heads up. I'll check it out.
Old Jan 25, 2013 | 12:17 PM
DynastyRacer22's Avatar
Where in the dessert are you from? I just moved to az from wa
Old Jan 25, 2013 | 06:46 PM
I live in Palmdale ,ca. Not as hot as Arizona, but it gets up there.
Azimmer
24
May 9, 2012 02:34 PM
silent702
Feb 9, 2010 08:22 AM
qnealstevens1104
Acura TL, RL & ZDX
Nov 11, 2007 06:22 AM
ujhonda
May 11, 2006 04:29 PM
jhitj
Mar 7, 2004 10:38 PM
