DPFI to MPFI conversion - Should I use a Y7 or B2 head?
so i want to go to mpfi and have picked up a y7 head and would like input on if i should use that or use my b2 head.. i know it will bump compression i think.. any input would be awesome
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
the head does not dictate the OBD nomenclature. they intake manifold and the distributor does. i would use the Y7 head simply because it has bigger intake valves. procure the PM6 intake manifold and use D16A6 distributor to keep it OBD0 (if that is what desired)
BlingBlingCivic
Mar 8, 2005 11:27 PM
