where to find NEW oem harness connectors
I am looking at trying to build my own tucked harness. I'm trying to find everything i need and price everything out. And I want to use all NEW oem connectors but for the life of me, I cann't find them.
Is there a site somewhere that sells the engine harness plugs, pins. Majestic Honda only shows the headlight harness and tail light harness plugs.
well where do people like rywire and chase bays get there connectors for their harnesses? if they are aftermarket, they'll have to do, as long as the arn't crappy ones that'll break.
they buy in bulk from suppliers. best bet? contact them and see if you can buy what you need from them.
why not reuse your old connectors?
not sure if this helps http://www.k20a.org/forum/showthread.php?t=38294
I prolly will have to, I just wanted at all to look new and good if I could. I got a couple that are broke, I'll just have to find them at a yard i guess..
i know you can get the ecu connectors and pins here:
http://www.hamotorsports.com/ecu-plugs-pins.html
dont know about the other connectors doe!
-Chris
-Chris
If you're referring to the sensor side connector housings, you'll be pressed to find authentic parts; most of what is used nowadays is 'aftermarket'...it's not impossible, but you're looking at minimum quantities starting around 500pcs.
www.xenocron.com sells the ECU connector kits, as well as K-Coil connector kits, and various aftermarket sensor/componnet connector kits; all authentic from the manufacturer. We also OBD1 and K-Series sensor-side terminals and seals.
NEWUNITEDRACETECH.COM
CLICK ON SUMITOMO AND MODEL HW.
this site will also give you the matching mate.
best part is you get part#'s that you can possibly google.
good luck.
remember that the sumitomo model to click on is HW.once you click on HW,click on sealed,once you click on SEALED,click on 090(2.3mm).
the rest you'll figure out.
good luck.
Hell yea thanks for that little piece of info. Who knows maybe they saw your thread and decided they can make a buck selling them. This helps me out cause I'm in the same boat with a few broken plugs trying to do this tuck harness. Thanks!
good luck.
good luck.
justahobbie
Audio / Security / Video
May 13, 2007 03:18 PM
