Random Misfire all 4 cylinders
Old Jan 16, 2013 | 02:37 PM
sh3didntl%k13's Avatar
Default Random Misfire all 4 cylinders
i have a stock 98 civic 1.6 non vtech. it was cold so i started it up and let it warm up something i dont usualy do. came back and started driving, out of nowhere starting missing and stumbling. replaced plugs, wires, cap and rotor didnt fix. did my ICM just go out
Old Jan 16, 2013 | 06:23 PM
xenocron's Avatar
Default Re: Random Misfire all 4 cylinders
Could be ICM, could be coil...could be both
Old Jan 17, 2013 | 06:49 AM
nanjay's Avatar
when did you replace your fuel filter, if its been years or you havent. I would seafoam the car, in gas tank and through intake then change your fuel filter.
Old Jan 17, 2013 | 09:02 AM
98vtec's Avatar
moderator emeritus
stop replacing parts guessing its the fix. first, how do you know its all cylinders? pull the codes?
you have no clue if its fuel or ignition related. so first you need to pull the codes and make sure there isnt something more than misfire codes and figure out what cylinders are misfiring. then you can go from there testing spark, fuel...etc.
ive been seeing way too many people just throw new parts at a car and see if it fixes the problem when you could buy some tools, or use the ones you have to figure it out. not only do you save money but you learn something in the process.
download or buy a helm manual and follow the flow charts for the codes you get. without actual data we can only provide possible solutions.
Lude #1
11
Jan 9, 2011 01:05 PM
manintux
Jul 7, 2008 05:52 PM
Riceeater702
Dec 29, 2007 01:35 PM
Cyber ITR
Apr 2, 2004 11:23 PM
Low_bias
Apr 26, 2002 07:53 PM
