1991 Civic RT4WD front end vibration
Old Jan 16, 2013 | 12:44 AM
Shpongled's Avatar
Icon2 1991 Civic RT4WD front end vibration
I have a vibration in the front passenger side. It only happens after about 30 MPH, and doesn't ever stop but quiets down the faster I go. It doesn't do it under acceleration, turning slightly right, or under hard braking. There is no play in any of the suspension components. I replaced passenger side axle because it was bad but didn't help any. I tried a different set of wheels and tires that are properly balanced but the problem persisted. Any help would be appreciated because I am at a total loss. Thank you in advance
Old Jan 16, 2013 | 12:47 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: 1991 Civic RT4WD front end vibration
check your damper
Old May 7, 2013 | 11:16 PM
Shpongled's Avatar
Still can't figure this out. Ive replaced passenger side knuckle with new wheel bearing and lower ball joint and nothing has changed.
Old May 9, 2013 | 05:07 PM
Shpongled's Avatar
Replaced the pads and rotors. Still no luck. Im willing to post a video of what it does in car if someone is willing to help me out.
Shpongled
Suspension & Brakes
Jan 10, 2013 11:33 AM
MikesEJ1
Mar 16, 2012 06:52 PM
Brycen
18
Nov 18, 2009 06:01 PM
jasonacura91
16
Apr 12, 2009 04:21 PM
WPeters
Nov 15, 2007 02:07 PM
