Noob timing question.
Old Jan 15, 2013 | 04:17 PM
CrxGrin's Avatar
Default Noob timing question.
I have the belt back on, I go to turn the crankshaft 3 teeth counterclock wise and it goes maybe 1 tooth before I can turn it anymore. Question is in the right up I foillowed I was supposed to jam the cam gears at up and marks even with block. Do I remove the pins I put in to stop the cam gears from moving before I turn the crankshaft?
Old Jan 15, 2013 | 04:37 PM
fcm's Avatar
fcm
Old Fart
Default Re: Noob timing question.
Yes, the cams, [or crank, it will turn a little] will not move unless the pins are removed. 94
Old Jan 15, 2013 | 04:46 PM
CrxGrin's Avatar
Thanks, so just to clarify so I dont have to keep messing with it. Once I turn it 3 teeth the cams WONT be pointing up and the line wont be lvl and thats right correct?
Old Jan 16, 2013 | 04:52 AM
kyden's Avatar
correct.
darkstormcr
Feb 22, 2012 09:19 AM
Aqueous5
Mar 5, 2008 09:15 AM
spcrxracer
Mar 7, 2005 08:48 AM
EKB18BPR3
Dec 9, 2003 07:08 PM
MrEg
Oct 12, 2003 10:50 AM
