Door Lock hard to open
Old Jan 15, 2013 | 05:25 AM
DAP97SI's Avatar
Default Door Lock hard to open
I have a 97 Civic HB with power locks. When I did the conversion the passenger side began to act up. It was very hard to open using the key from the outside. Since I don't use the passenger side often enough, I didn't mind. Now 2 years after the conversion, the driver's side is doing the same thing. The door locks and unlocks fine from the inside using the lock button or manually. The problem is whenn I use the key to open the door, it feels very hard to turn the key. What part do I need to replace?
Old Jan 15, 2013 | 06:19 AM
Former User's Avatar
Default Re: Door Lock hard to open
Spray some WD40 into the key hole of the lock cylinder and then repeatedly turn the lock back and forth with the key. This should fix the problem.
Old Jan 15, 2013 | 06:28 AM
DAP97SI's Avatar
I will give this a try, thanks.
Old Jan 15, 2013 | 08:11 AM
DumpdEJ6's Avatar
I like the tuna here
QFT. I used PB Blaster, but potayto/potahto
Slade Exulis
Sep 23, 2018 04:53 PM
ayau
Feb 10, 2013 01:45 AM
blacktibby07
Feb 5, 2011 06:37 AM
gezulu
Honda Civic (2001 - 2005)
Sep 13, 2008 04:02 PM
