Darton or Golden eagle
Old Oct 20, 2002 | 01:50 PM
96cxt's Avatar
Default Darton or Golden eagle
I am building my b18c1 block. This is going to be my street/stip car, and I am going to boost about 20 to 25 psi on it.
Which sleeves should I go with???
Darton or Golden Eagle ????
If anyone of you are using one of these let me know the pros and cons of them.
thanks
Old Oct 20, 2002 | 02:33 PM
Sonny's Avatar
Default Re: Darton or Golden eagle (96cxt)
Darton ->
-DIY = less downtime
-Can replace one sleeve at a time
Darton ->
-DIY = easy to screw up if done wrong
-No warranty
Golden Eagle ->
-Warranty
-Assurance that the work was correctly done (that's all they do)
Golden Eagle ->
-Downtime
-Cannot replace only 1 sleeve if necessary
Sonny
Old Oct 20, 2002 | 04:08 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Darton or Golden eagle (Sonny)
GE get's my vote.
Vince is here on the board somewhere...
If I was doing what you're doing, I'd go GE.
Old Oct 20, 2002 | 07:30 PM
1 2 NV's Avatar
GE only, even though u have to replace all at one time, way cheaper than darton.
Old Oct 21, 2002 | 10:29 AM
X-Mazda 3 Racer's Avatar
Default Re: Darton or Golden eagle (hondaatwsu)
Not to mention, Golden Eagle sleeves are better. And the block comes with a warranty!!!
[Modified by V8KILR, 7:29 PM 10/21/2002]
Old Oct 21, 2002 | 11:22 AM
2dark2bslow's Avatar
Default Re: Darton or Golden eagle (V8KILR)
where does the wrranty on the block come from, need all available info cuz my motor is getting pulled oout right now.
thanks
josh
Old Oct 21, 2002 | 11:54 AM
Default Re: Darton or Golden eagle (2dark2bslow)
The warranty comes from Golden Eagle Mfg. Warranty includes:
90 warranty against sleeve sinking ot water leaking into the oil chamber
3 year warranty against sleeve cracking due to boost pressure. Up to 60PSI!!!!!( does not include detonation or rod failure!!! )
What more do you need?
[Modified by V8KILR, 8:55 PM 10/21/2002]
Kwuaymaikrup
Sep 17, 2009 04:03 AM
Mr. K20addict
147
Mar 24, 2008 10:04 AM
rocket256
Nov 26, 2003 09:45 AM
96cxt
Oct 22, 2002 03:12 PM
BowSeR
Jan 30, 2002 07:23 AM
