Fuel Pump On B16A1
I have a b16A1 in my Crx. Im running it on a stock fuel pump, but when its at idle it kinda of sounds like it is going to die. Can it be my fuel pump? Please help! If it is, what kind should I get and how much do they cost?
Guest
Posts: n/a
i had the same problem with my crx with a jdm b16a. i blew out my fuel lines running to and from the motor and they were both clogged. i also got a new stock crx si fuel pump and a 99 si fuel filter. you might be getting bad spark. i would check the plugs, wires and the distributor. my car runs hard now.
prestonpark
Mar 15, 2006 09:45 PM
