'90 Si Rusty Mofo
Old Jan 13, 2013 | 06:36 PM
fujiwaratofu86's Avatar
Default '90 Si Rusty ****
So I decided to finally rid of the rust hole in the passenger side of my '90 si hatch the other day (damn you midwest winters) Turned out to be a bit worse than I had thought, as I had to cut off quite a bit of the rocker and quarter panel. This obviously isn't just a little patch job, so i searched around to see if there were any patch panels out there for my car and it appears that there is only a few for the EF chassis, and nothing looks like it will help solve my issue (unless i get a whole new quarter panel which I'm not cutting apart just for this little bit) I was curious if anyone else has had to deal with patching sheet metal in this area before, and if fabbing my own piece would be the best option in this case? Any suggestions would be great.
Old Jan 13, 2013 | 09:14 PM
4drEF's Avatar
Keyboard Humorist
Default Re: '90 Si Rusty ****
Have you tried http://www.rustrepair.com/?
Old Jan 13, 2013 | 09:39 PM
Yeah I checked it out and the only thing they have is the wheel arch and I don't think it covers as much as I need.
Most sites that I've seen only have the wheel arches and rocker panels. I was just curious if anyone was aware of any place that has more replacement panels than just those. Not a whole lot of replacement parts are available for the EF's it seems like.
Old Jan 13, 2013 | 09:45 PM
1987SEEAREEX's Avatar
Try going to a pull-a-part with a battery operated die grinder... cut the piece out of any dx, hf, si..May be your best option. Thats what I would do. Make sure and cut out more than you need though, lol
Old Jan 13, 2013 | 10:03 PM
^^Actually a pretty good idea, I may have to end up doing that. Just got to get myself a battery operated die grinder now LOL
Old Jan 14, 2013 | 08:58 AM
dubyas1989's Avatar
http://www.andysautosport.com/honda/...anels/sherman/
Have you tried these guys I got some rockers from them recently
socialistic
Dec 17, 2010 11:47 AM
JDM-KIDD
Paint and Body
Feb 7, 2010 04:19 PM
sicivicguy
May 22, 2006 09:26 PM
