Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Surging idle searched help before I lose it :-p
Old Jan 13, 2013 | 02:47 PM
Hondapreludeg's Avatar
Default Surging idle searched help before I lose it :-p
I have a 2001 Honda civic ex just replaced the engine. After 200 miles I ended getting a surge after warm up. I cleaned IACV , replaced throttle body and intake gasket, cleaned throttle body and egr, new thermostat PCV valve and coolant temp sensor, checked for vacuum leaks, bled coolant system. Did relearn idle procedure multiple times. Had an extra IACV didn't make a difference. It runs mint until warm up and the surges and drops back down to 800rpm and surges a little bit HELP :-/
Old Jan 16, 2013 | 03:30 PM
Default Re: Surging idle searched help before I lose it :-p
Please help I just replaced all hoses too. It surges more when my foot is on the brake. Hmmmm
Old Jan 16, 2013 | 03:36 PM
toyomatt84's Avatar
Sanji
If its surging when you've got your foot on the brake, you've got either a vacuum leak in the booster or in the vacuum lines.
Old Jan 19, 2013 | 06:04 AM
Theres only the one vacuum line that goes to the intake manifold right? I replaced that and inspected all other hoses.
Old Jan 19, 2013 | 06:16 AM
toyomatt84's Avatar
Sanji
Correct. Have you tried taking off the portion of the hose that connects to the brake booster, then clamping the end to ensure that its closed? That'll tell you if there's a leak in the brake booster.
Old Jan 20, 2013 | 04:50 AM
Ill pull the hose off and close off the end to see if it runs any differently thanks for the idea
Old Jan 22, 2013 | 01:05 PM
Zedt3's Avatar
Well, any results?
Old Jan 23, 2013 | 09:50 PM
JKulet's Avatar
I had the same problem BUT.
Did you try adjusting TPS?
That fix my idle because the tps is very sensative and the slightest nudge/movement can cause rough idle, low idle, high idle etc.
There should be DIY for TPS.
Posted from Honda-tech.com App for Android
Old Jan 29, 2013 | 12:28 PM
Tried blocking the vacuum hose ... Didn't change any. I noticed when I press the throttle it gets more surge to it.. When pressing the brake with no vacuum hose idle surges the same hmmm..
Old Jan 31, 2013 | 03:34 AM
Will the TPS cause a surging idle though??
Old Jan 31, 2013 | 05:52 AM
I had another throttle body laying around even out that one on with no changes in how it is acting. I also swapped my intake manifold. Really at a loss right now this has me stumped!!!
Old Feb 6, 2013 | 08:07 PM
tjsilvasr's Avatar
Man it sucks to have a vacuum problem. Did you put a vacuum gauge on it? Also check all vacuum switches with a hand held vacuum tester to make sure they don't bleed down.
Try removing and capping each vacuum circuit to the manifold one by one while it's running. When you find no change remove the cap and reconnect the line and do the next one. When you see a change (the surging stops) check every valve, connection and line (Rubber & Metal) on that vacuum circuit.
If you don't find a bad vacuum circuit try spraying WD40 on all gasket connection on the intake manifold. if the surge stops while spraying an area replace that gasket.
Good luck
Old Feb 16, 2013 | 05:03 AM
So after trying everything you could think of i remembered hearing of the same surging idle problem in the honda minivans and with those it was 9 times out of 10 the power steering pressure switch. I unplugged mine and the car runs mint. The power steering just doesnt work as well. I am replacing the switch today.
Old Feb 16, 2013 | 12:22 PM
jdmeg6118's Avatar
Nice, glad you got it runnin right. Just curious how did you're last motor go out?
Old Feb 18, 2013 | 02:23 PM
Bought the car with a bad motor the guy never changed the oil and ran it down to less than a quart was seized. I actually freed it up but then threw a rod right through the oil pan
Tanner911
Mar 2, 2010 06:55 PM
slob20ef
14
Apr 1, 2009 04:18 PM
luv2boost
Jun 2, 2008 06:33 PM
RiceBurninCX
Jan 24, 2008 02:02 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
