Radiator leak 97 Civic
Old Jan 13, 2013 | 11:25 AM
iiPancho's Avatar
Default Radiator leak 97 Civic
Hey guys, looked around but I haven't seen any issues around here like this one. Went to do an oil change yesterday and as I was jacking the right of the car up to put a stand under it, it started to dribble oil. I go to lift the other half of the car and it stops. I get under and notice the only wet spot is where the rubber boot is on the bottom mounting point. The radiator is 2 years old and is the aftermarket choice at the Honda Dealership. I attached a picture to give a better understanding.
Old Jan 13, 2013 | 11:28 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Radiator leak 97 Civic
Oil or transmission fluid? The car is an automatic isn't it?
Old Jan 13, 2013 | 11:36 AM
iiPancho's Avatar
It's a manual trans. It is coolant. I'm not sure if its split. It's only wet at this mount point.
Old Jan 13, 2013 | 11:39 AM
The Grumpiest
Sorry. You said it was dribbling oil.
Inspect the rad. Especially at the top where plastic meets the metal. You could get it pressure tested as well.
Old Jan 13, 2013 | 11:46 AM
Former User's Avatar
Any chance it's just spilled coolant from topping off? If not, I'd just replace the radiator.
Old Jan 13, 2013 | 11:54 AM
iiPancho's Avatar
Whoops. I just seen that typo. Last time I filled the radiator, I used a pressurized filler and it doesn't spill. I just find it odd that the rubber boot is soaked with coolant, but dry everywhere else.
Old Jan 13, 2013 | 11:56 AM
gzes's Avatar
Must hqve a crack in the radiator imo jist get a racing radiator full aluminum and inexpensive
supracord
Jun 20, 2011 10:42 AM
ujhonda
May 28, 2006 08:16 PM
iCe_2x
Jul 12, 2005 03:40 PM
KingJeff
Aug 1, 2004 05:59 PM
monicle
11
Oct 13, 2003 11:48 AM
