Unused O2 sensor damaged if left in exhaust?
Old Jan 12, 2013 | 06:53 PM
GagnarTheUnruly's Avatar
Default Unused O2 sensor damaged if left in exhaust?
Just like the title says, can a factory O2 sensor be damaged if it is left in the exhaust after an OBD2-OBD1 conversion?
I want to be able to use an OBD1 ECU for a few weeks, but I don't want to damage the secondary O2 sensor because I'll need to get the OBD2 ECU back in for smog in a few weeks. I can't think of any reason it would be damaged but I understand O2 sensors can be fragile.
Old Jan 12, 2013 | 08:45 PM
mtber's Avatar
Default Re: Unused O2 sensor damaged if left in exhaust?
No it shouldn't effect the sensor.
Old Jan 15, 2013 | 08:26 AM
Rtype16's Avatar
It can in some cases. When the O2 is being used it will have a heater element that will heat the sensor to operating temp. When not in use without this it has a chance to become clogged. Just jack up the car and pull it out and replace with a plug. Just to be safe.
Old Jan 15, 2013 | 08:29 AM
OK thanks for the help guys. I've got some toasted spark plugs I can use.
DC2R96
Feb 11, 2011 02:17 PM
phoshyzzle
Oct 18, 2009 07:52 PM
