Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Honda civic makes scraping noise in gear with no gas
Old Jan 12, 2013 | 06:11 PM
wstewart90's Avatar
Default 2002 Honda civic makes scraping noise in gear with no gas
I have a 2002 Honda civic that makes a scraping/dragging noise while the car is in gear. The noise isn't there when I press the clutch down or coast in neutral(Just to test it). It almost feels like something underneath the car is dragging it and the car slows down as if it was catching on something. I've noticed this in first through third gear. This car has been in a crash and the back left door is banged up as well as the bumper around the front of the back left wheel. I've recently had the breaks replaced and a Honda Mechanic told me that the tie rod and ball joint boots were torn as well as the low control arm bushing. What do you think could be causing this?
Edit: The noise doesn't seem to be there or at least the dragging seems to be gone when I press the gas.
Old Jan 13, 2013 | 09:32 AM
thecca's Avatar
Default Re: 2002 Honda civic makes scraping noise in gear with no gas
Release bearing in the transmission?
Old Jan 15, 2013 | 02:39 PM
CKC02's Avatar
im having the same problem with my 02 civic and i read its the input shaft bearing but when i park i can also smell clutch burning i just want to order the parts the tear it down so its all done in the same day but because the clutch is slipping do i need ne input shaft bearing any help is great
lilrak72
20
Apr 29, 2016 04:56 AM
Lcurle
Nov 6, 2012 10:52 AM
mprather111
Sep 3, 2012 11:16 AM
chueflee
Nov 13, 2007 10:36 AM
BudMan
Aug 11, 2004 04:58 AM
