2006 Civic: Manual VS Automatic (lower gear ratios?!?)
I have an automatic 2006 civic, and drive my friends manual and I must say their is a noticeable difference* on the highway (5th vs 5th) ( when coasting )*
He endured me they were the same trannies and I was "wrong" but I searched and found this on the honda website:
5-Speed Manual Transmission
Gear Ratios:
1st: 3.143
2nd: 1.870
3rd: 1.235
4th: 0.949
5th: 0.727
VS
Compact 5-Speed Automatic Transmission
Gear Ratios:
1st: 2.666,
2nd: 1.534,
4rd: 1.022,
4th: 0.721,
5th: 0.525,
Automatic has much lower higway gear...so will get WAY better MPG...if the manual had the same low gear it would get INSANE gas mileage...
Any ideas?!?
Thanks!!!!
Gear Ratios:
1st: 3.143
2nd: 1.870
3rd: 1.235
4th: 0.949
5th: 0.727
VS
Gear Ratios:
1st: 2.666,
2nd: 1.534,
4rd: 1.022,
4th: 0.721,
5th: 0.525,
Any ideas?!?
Thanks!!!!
manual has higher ratio on the last gear to keep it nearer the power band to allow for easier acceleration if needed. The Si's also have a huge jump on the 6th gear. The RPMs drop 1K between 5th and 6th when shifting whereas between any other gear the RPMs drop about 500 or so. 3K RPMs in my FA5 in 6th gear is about 63MPH/100KMH.
Automatic trannys are not direct drive trannys and don't need to rely on RPM as much at cruise speeds.
Good thought...
But that does not make a great deal if sense to me...if you want power then you downshift... I would much rather have a low high gear and have to shift then to loose MPG'S
And the SI is a but better (due to 6 speed)
But I'm still disappointed...
Close-Ratio 6-Speed Manual Transmission
Gear Ratios:
1st: 3.267,
2nd: 2.130,
3rd: 1.517,
4th: 1.147,
5th: 0.921,
I kinda think its a conspiracy to make people buy autos (more $$) and to not make cars to efficient... But IDK...
Gear Ratios:
1st: 3.267,
2nd: 2.130,
3rd: 1.517,
4th: 1.147,
5th: 0.921,
Sorry missed 6th gear!!!!
6th: 0.659
And here is site link
http://www.honda.com/newsandviews/ar...=2005082958648
6th: 0.659
And to debunk your calim 97emsedan...
Here is the 2006 Toyota corolla transmission gears...
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: 0.885
5th: 0.725
4-Speed Automatic Transmission
1st: 3.643
2nd: 2.008
3rd: 1.296
4th: 0.892
Almost identical...(1-4)... The manual equipped corolla would get better MPG's and its safe to say a 5 speed automatic would look the same (similar gears)...
Any explanations?!?
Maybe it is a conspiracy ....
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: 0.885
5th: 0.725
1st: 3.643
2nd: 2.008
3rd: 1.296
4th: 0.892
Any explanations?!?
Gear Ratios:
1st: 3.143
2nd: 1.870
3rd: 1.235
4th: 0.949
5th: 0.727
VS
Gear Ratios:
1st: 2.666,
2nd: 1.534,
4rd: 1.022,
4th: 0.721,
5th: 0.525,
Any ideas?!?
Thanks!!!!
Gear Ratios:
1st: 3.143
2nd: 1.870
3rd: 1.235
4th: 0.949
5th: 0.727
VS
Gear Ratios:
1st: 2.666,
2nd: 1.534,
4rd: 1.022,
4th: 0.721,
5th: 0.525,
Any ideas?!?
Thanks!!!!
The Si is sort of hard to compare being that they use a completely different engine. Also it revs significantly higher in 6th than a base model does in 5th despite having an extra gear. This is where you need to figure in that final drive I was talking about earlier.
blackriceman
Mar 11, 2004 07:18 PM
