DC5 Lowered supsension problem
Old Jan 11, 2013 | 03:17 PM
AlexTank's Avatar
Default DC5 Lowered supsension problem
Ive searched through here and another RSX forum and haven't really found the answer to my question with my tie rods. Basically i lowered my car on buddy club N+ and there is not enough length/ adjustment in the tie rods to properly have the front aligned. I would really appreciate any replies or just pointing me in the right direction.
Old Jan 11, 2013 | 03:23 PM
doood's Avatar
been there done that
Default Re: DC5 Lowered supsension problem
inverted tie rods are longer than the oem and give you more room to adjust but wear much quicker
i never understood how people have this problem with the n+. mine are maxed out in front and never once had an issue getting toe back to 0. even when i had shorter springs in front and was slammed never had an issue.
Old Jan 14, 2013 | 04:37 AM
JDM-Junior's Avatar
Don't forget that it's also about how much camber you're running up front, too much and you won't be able to set up the toe correctly.
Old Jan 14, 2013 | 07:59 PM
jdmtodadc2's Avatar
Do you me by inverting the tie rods. Turning them upside down or installing them on the bottom side of the mounting arm on the coilovers? Just want to make sure we are on the same page.
Old Jan 14, 2013 | 09:24 PM
doood's Avatar
you cant run oem tie rod ends inverted as far as i know. you need aftermarket rod ends like so:
Old Jan 14, 2013 | 10:09 PM
b18_crx's Avatar
depends on the coilovers. With megan coilovers you actually have to invert the oem tie rods. Thats the way the coilovers are designed.
Old Jan 15, 2013 | 05:44 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
^correctly, only a few coilovers are designed to install the tie rod end inverted.
Tie Rod ends are tapered so they only go in one direction correctly.
Old Jan 20, 2013 | 02:51 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Ive not seen inverted tie rods wear any quicker than OEMs....
Old Jan 20, 2013 | 07:37 PM
Gtimportfanatic's Avatar
i use N+ on my EP3 and a good friend of mine uses it on his DC5, both installs done by me, we had no issues dialing in the Toe, i personally did my own alignment and he got his done at another shop. Do you mean that the tie rods pop out before u can get the wheels straight?
Old Jan 21, 2013 | 09:12 AM
AlexTank's Avatar
Yes that is the problem I am having
Old Jan 21, 2013 | 06:28 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
It is a common issue and inverted tie rods are the answer....
Bleakened
Suspension & Brakes
Jan 2, 2017 08:08 PM
cees
Mar 1, 2013 08:39 PM
Boilermaker1
Apr 4, 2005 08:59 PM
