Racing Port work Vs. Extrude Honing
Old Oct 20, 2002 | 12:26 PM
SilverEk3dr's Avatar
Default Racing Port work Vs. Extrude Honing
I have been doing a little research into wether I should get my head extrude honed or have it ported out......but I cant really seem to come to a decision. I heard before that you would want smooth intake runners for an FI setup, but not for N/a (since the imperfections in the casting actually increase velocity/ mix fuel and air better)
Does anyone have there head/intake extrude honed? What do you think versus having it ported?
Thanks
Mark
Old Oct 21, 2002 | 12:22 AM
riceboy's Avatar
Default Re: Racing Port work Vs. Extrude Honing (SlvrEj6Dx)
port the head, extrude hone the turbo
BTW, post this topic in the tech forum and you will more than likely get more responses.
Old Oct 24, 2002 | 08:48 PM
StorminMatt's Avatar
Hand porting is better for heads since material can be removed only where it will be beneficial to do so. For instance, you generally don't want to make your ports bigger where the manifolds/headers bolt to the heads. But it is very beneficial to clean up the ports around the valve seat area. However, extrude honing will tend to remove at least some material everywhere. Extrude honing is better on pieces that cannot be ported in the ususal manner (ie intake manifolds).
Flexin5
11
Jun 4, 2006 05:31 AM
ekim952522000
Mar 29, 2006 03:38 PM
xplanetearth420x
Oct 23, 2005 05:23 PM
2ndgent3g
Nov 25, 2004 09:20 PM
