02 accord f23a4 to h23a vtec wireing help please
hi so im in the middle of a swap from an f23a4 to a jdm h23a and i need help figuring out a few things with the ecu, wireing, and what other problems im going to once i get it started
so heres my specs: car is obd2b, and im useing the f23 wire harness, jdm pcb ecu which is also obd2b
my first question is the h23 does not have a vtec oil pressure switch and my f23 did and ive been hearing that if i dont get one or bypass it i wont have vtec. is this true? and if so what do i do.
second the h23 has an iab the f23 does not so there is no wire in the harness for the solenoid on the vacuum reservoir.
third the iac wiring and hose routing? any advice would be cool
and fourth theres a sensor on the side of the motor under the distributor that only has 1 wire and idk what it what it does and the f23 did not have it
now the pcb ecu i could not get a straight answer on google does it have an immobilizer?
so thats what im stuck on right now and help with this or anything else is greatly appreciated
obviously i googled all this and cant get a straight answer thank you
See if your vtec pressure switch will swap over.
You will need to get a vacuum diagram and just match everything up. You will need to run an iab wire kit from the ecu to your engine. You can do an internet search for "axidworks"..he sells kits.
That wire could be for the vtec pressure switch. Can you take a picture ?
Ok thanks for the help right now I cant post a picture of the sensor but it uses a yellow/green wire and it next to a 2 wire sensor that hooked right up with my harness
Did you finalize your engine swap?
I have a 2002 Accord - 2.3L F23A4 ULEV - Automatic and am looking to swap with a H23A. Would like to use my transmission, wiring harness. Would like to use H23A ECU and am unclear as to wiring.
Can I use my harness with H23A ECU?
Will H23A ECU plug into my harness or do I modify?
What is the best ECU to use?
Can my ECU be reprogrammed?
Are there any transmission differences?
If I use my harness what other sensors do I transfer?
Would it be better to user a H232A harness and ECU?
Thanks!
Thanks!
I've never done the 3-wire Accord before, so I don't know. It should plug into the H23's IACV cause that one's also a 3-wire IACV. Otherwise, search.
One way to find out. Plug it in and see.
Thanks!
Thanks!
If you're running the JDM ECU, VTEC will still work because JDM motors don't come with VTEC pressure switch. Now if you switched over to a chipped ECU, it will look for it. Just swap over the one from your F23. Remove the bolt that is in place of it on the JDM H23A VTEC. It'll screw right in.
You can hook it up by vacuum and throw away the black box bolted underneath the IM. Less wiring headaches. I did it to my H22A, ran strong.
That I assume would be your temp gauge sender; since, it's only a single wire.
accuder
Feb 11, 2007 07:08 PM
