b17 crank, rods, b16 manley pistons, b16 block, b16 stroker, arp
Old Jan 10, 2013 | 03:14 PM
deckster333's Avatar
Default b17 crank, rods, b16 manley pistons, b16 block, b16 stroker, arp
Located in Boston. Prefer local pick up. PICS UP SOON
pm if interested!
-B16 ARP HEAD STUDS-
Torqued down a few times, never over torqued - SOLD
-B16 BARE BLOCK 81mm BORE-
Comes with, matching mains, windage tray, oil pick up, timing belt only. - SOLD
-B16 OIL PAN AFTERMARKET-
Like New, a few scratches - SOLD
-B-SERIES CRANK PULLEY-
(small chip only, ran perfect) - SOLD
-B17 ROTATING ASSEMBLY - (B16 BUDGET STROKER SETUP) -
Crankshaft was professionally lightened, balanced and micropolished. OEM journal sizes. Rods were lightened and end-balanced, fitted with ARP bolts correctly, machined tangs for TYPE R rod bearings. Pistons were balanced. I have receipts for all machine work. This setup has less than 1000 miles since machine work was done. Smoothly revs to 9500 rpm no problem!!
*b16 block just needs rehone and rering in cylinder #3 due to either wash out or piston/wall clearance. Will do package deal with block.
INCLUDES:
B17 CRANKSHAFT
B17 RODS (ARP BOLTS) W/81mm MANLEY 8cc FORGED PISTONS
SOLD SOLD SOLD
Old Jan 14, 2013 | 06:02 AM
Default Re: b17 crank, rods, b16 manley pistons, b16 block, b16 stroker, arp
Bump these parts are legit..hundreds in machine work alone!
civhx
Jun 30, 2008 12:39 AM
dominicanito49
Jul 18, 2006 06:41 PM
SiR Inspired ED7
Apr 3, 2006 07:51 PM
SiR Inspired ED7
Apr 3, 2006 07:50 PM
EgGriff
Mar 12, 2005 08:41 AM
