JDM H22A Type S Euro R Engine LSD Tranny 98+ would this fit in my 1995 accord sedan
hey im new to this n iwas wondering if anybody knew if it was possibe to put a JDM H22A Type S Euro R Engine LSD Tranny in my 1995 honda accord sedan. has anybody out the ever done this swap?
I have a h22a euro r type in my ek with a LSD tranny, l didnt do the swap but l bought it that way. I don't know if that helps you at all
Yes it can be done..... It has been done more than a few times.
I thought you said before that you had an H22A1..... doesn't matter I guess it's still an H22....one in the same.
The H22 is a fairly easy swap into the CD Accords chassis. These chassis come with H22's & F20B's in other markets. Blocks are pretty much drop in and go... it's the wiring that is different with the different OBD H22's.
curious i've seen jdm h22a's with a h2b b16 tranny swap, is it possible to do a B16 with lsd tranny in a f22a1? that would be INTENSE
Or do you mean an F2B? aka a B16 trans bolted up to an F22A1 engine? It would physically be pretty much the same kit as an H2B, the two blocks share the same bell housing.
In saying that! An F2B would make for some pretty quick shifts to stay in the power range of an F22A1. 5500 RPM comes at you pretty quick with a B series trans.
pcguy760
Mar 12, 2007 08:45 PM
PoorBoyRacer
Sep 27, 2001 06:37 AM
