Replacing 1995 honda accord fuel pump
Old Jan 10, 2013 | 09:24 AM
qhiggy's Avatar
Default Replacing 1995 honda accord fuel pump
I read online when replacing the fuel pump on a 1995 honda accord, you mush go in the trunk area, lift the carpet and there should be a round plate, remove it, disconnect the wire harness, and so on. Does that sound right? Its a 1995 honda accord ex.
Old Jan 10, 2013 | 09:33 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Replacing 1995 honda accord fuel pump
incorrect, that's the fuel sending unit you are accessing. To access the fuel pump you must drop the fuel tank.
Old Jan 10, 2013 | 09:37 AM
gdrew888's Avatar
CAUTION, thread hijack...
Does that apply to the 1991 model year too? Thanks.
Old Jan 10, 2013 | 09:39 AM
qhiggy's Avatar
awesome, thanks for the help. I thought is sounded a little bit off.. is the walbro 255lph fuel pump pretty good? I am upgrading the fuel injectors, already have a cold air intake, waiting on headers, and upgrading to a cat-back exhaust.
Old Jan 11, 2013 | 08:05 AM
Community Builder
it might, a simple search will better answer your question because i'm not sure.
unless you're running a turbo application a fuel pump of that capacity is pointless, and this also applies for the fuel injectors.
Michele Walker
May 24, 2018 04:30 PM
GK2
Oct 23, 2013 05:36 AM
hxtreme
Oct 18, 2009 05:24 PM
mtnman
Aug 22, 2004 08:10 AM
