h22a full wiring diagram for project
right im not new to forums but a am to this one ive used the search function to no avail so....
Q1 what would be the best ecu to use for my project for tuning with chrome ? with a h22a jdm import
Q2 i have found the ecu pinouts but not sure were everything would go bearing in mind the engine is not going into a honda
thank you if someone can help me out
definitely sounds like what you need is a service manual for the prelude with wiring diagrams.
Crome runs on almost any obd1 ecu from an integra or civic (except the p07). You can choose which ecu you want based on what hardware you want on it such as vtec, iab, knock sensor and so on.
