flashing oil light? but plenty of oil
my oil light has been coming on for the past week and flashing when in gear and when in neutral its just a solid light. but im not low on oil? do you think i have a sensor out or something?
Sensor out should never come on if I recall correctly. I know when it is unplugged it won't come on at all.
Sounds like bad oil pump, clogged pickup, badly dented oil pan, to the worst cases spun bearing or cracked crank.
Two things come to mind, 1 of which is gonna make you say wtf, but i have personally experienced both.
1. As stated, oil pump can be going out, clogged etc.
2. Alternator, yes alternator. There is a dioad in it that goes out and causes the oil light to flash, sometimes other weird electrical issues.
Put a mechanical oil pump gage on the car and see what your oil pressure is. If its good when the light is coming on the id look into alt or possibly oil pressure sending unit.. If it is indeed low, oil pump system. I put a t fitting between block and oil pressure sending unit, that way i know both units are receiving same pressure.
Good luck, post back with your findings.
its doesn't start flashing untill about 10 minutes of driving. the weird thing is vtec still engages ? ill look into check the oil pressure this weekend.
Souds liek interrnal loss of pressure to me. If this were to occur while at idle then your vtec woudl stil work as the pressur increases with rpm. I would be checkign the oil pressure at idle with a pressure gauge and then going form there.
Any tiem the oil light comes on and flashes it means you are expereicnes momentary loss in oil pressure. If the sensor is fucked then the oil light would come on and stay on.
If it is flashing quickly with no pattern to it then you have oil presssure loss.
I would check the connection on the oil sending unit. Some times it gets moisture and it doesnt get good contact. This has happened to me and a few of my friends.
How old is the oil? Filter?
What type?
Sounds right about confirming you have pressure first. It's good to know what's going on in the motor even if it is just a loose wire on the sensor
What type?
ive had this same problem on my 95 lude s ive got single cam 16v motor it ive had my lude for going on 4months its been on maybe 5times but when i cut car off it goes off and dont pop up till about amonth later ??
