clutch or what?
Ok so I own a 95 teg 4 dr... and a week ago my shift was getting a lilo hard to shift... a week later I changed my cmc and bleed it out and my pedal is pumping very hard and good enough... but the problem is I can't shift in any gears.... the only way I can drive is to turn it off shift to gear 1 and turn it on and it will jerk off and start moving without me letting my legs off the pedal... I know the clutch work cuz wen I shift I can feel it grabbing but its also grabbing differently... usually wen I let off my clutch pedal, I would let it out half way and then I will feel it grabbing.... but this time it past halfway to where I'm almst letting my foot off and then I can feel it grabbing... so any suggestion wat might go wrong? Pressure plate? Clutch cable? I need answer fast cuz my baby teg died for 2 weeks now and I miss riding her...
Pressure plate problem not disengaging the clutch, spring problem on the clutch, loss of pressure in the clutch hydraulic system, or air in the hydraulic system are my guesses. How many miles are on the clutch set-up?
If you have a 95 Integra with the stock transmission, you do not have a cable transmission.
Well I just bought this car like 6 months ago so my guess is the clutch might be there for a. Long time cuz my car is completely stock... so I guess might hafta replace the pressure plate then?
