Head Gasket or valve cover
Old Jan 9, 2013 | 05:02 PM
jonyi27's Avatar
Default Head Gasket or valve cover
I have a b20z short story quick there's a oil leak not sure what it is can't post pic cause on cell phone, but it's near the Altenator bracket like there's a ridge right where the head and block meets.... Driving me crazy I don't know if it's bad valve cover gasket or the head Gasket... I found couple threads but it's all with like ARP head studs and it's a b20vtec so just wondering, some say it's really rare for the H/G to leak oil maybe it's traveling down idk happens when I am at high rpm
Old Jan 9, 2013 | 05:05 PM
Brandonb92's Avatar
Default Re: Head Gasket or valve cover
turn your heat or ac on and see if you smell coolant ive heard thats a way to check
Old Jan 9, 2013 | 05:18 PM
jonyi27's Avatar
Old Jan 9, 2013 | 05:20 PM
jonyi27's Avatar
It's that ridge behind cylinder 4 (closest to timing belt area)
Old Jan 9, 2013 | 05:21 PM
jonyi27's Avatar
No coolant smell just oil sometimes
Old Jan 9, 2013 | 05:27 PM
fcm's Avatar
fcm
Old Fart
So clean the area real good, use a degreaser so area is completely clean, start engine, keep an eye on the area as you rev the engine leak location should become evadent. 94
Old Jan 9, 2013 | 05:28 PM
jonyi27's Avatar
I did and still don't know but I just cleaned it all so ill see it tomorrow
Old Jan 9, 2013 | 08:25 PM
bigislandc2's Avatar
Go buy some oil leak dye and use a uv light and watch for it.. be sure its clean and always clean not only that area but from valve cover too. remember oil will always flow down
Old Jan 10, 2013 | 11:56 AM
wunfstgsr's Avatar
Loved
Community Favorite
might be the cam seals.
Old Jan 10, 2013 | 12:02 PM
GagnarTheUnruly's Avatar
Oil will go sideways for a mile but never up. Clean thoroughly and then look for the highest spot that's wet. It could honestly just be spills from refilling the oil.
Old Jan 10, 2013 | 08:17 PM
teamkosmos's Avatar
Cams seals ! Vtec selenoi !
Old Jan 11, 2013 | 12:46 AM
jonyi27's Avatar
It's just a stock b20z no b20v so no vtec solenoid, and can seal is on the complete opposite side but ill try and see, it's just frustrating
Old Jan 11, 2013 | 12:42 PM
wunfstgsr's Avatar
Loved
Community Favorite
The Cam seal not can seal is on the "timing belt" side, just where you claim your leak is! so id check your cam seals.
Old Jan 11, 2013 | 06:38 PM
jonyi27's Avatar
that was auto correct, didnt catch it, do i need to take off the timing belt to check it?.....what do yall think of using a stop-a-leak item?
Old Jan 11, 2013 | 06:59 PM
wunfstgsr's Avatar
Loved
Community Favorite
lol stop a leak lol wtf is that? no forget that b.s.
Sometimes its tricky, if you still have the oem covers behind and over the cam gears then you might need to remove the cam gears and timing belt. Just lock the cams in place with a pin on top of the cam plates and remove the timing belt and gears and if it is the cam seals remove them and instal new ones correctly. If you dont have the cover behind the cam gears just remove the front cover and look behind the cam gears for the leak.you must remove the valve cover and remove the two bolts on the cam cover to expose the cam gears.
Old Jan 11, 2013 | 07:05 PM
jonyi27's Avatar
like the oil they sell at autozone and other spots like "lucas stop leak" ....but i thiink if i do that i should just do everything new H/G T-belt and all those seals
Old Jan 11, 2013 | 07:50 PM
wunfstgsr's Avatar
Loved
Community Favorite
Well than just pull the head and rebuild the top end and do it right.
Cole Peters
Oct 18, 2015 06:04 PM
bob441
Apr 10, 2012 05:53 AM
n20delslow
22
Oct 31, 2011 10:25 AM
AGPSuperstar
Feb 17, 2003 12:15 PM
Asahi
Feb 2, 2003 05:24 PM
