2008 rear compatible
will an 08 4 dr si oem rear lip fit a 4 dr civic hybrid .
I think they do because the rear bumpers have the same part number but not sure if the hybrid rear lip is different then the si .
one more question will a 2010 front bumper just bolt on to an 08 ?
I think they do because the rear bumpers have the same part number but not sure if the hybrid rear lip is different then the si . They should have different part#'s...The rear HFP lip on the Si is cut to fit the Si exhaust tip. And the black "diffuser" part is also goes higher up than the non-Si lips.
Si bottom, non-Si top
Si top, non-Si bottom
You need the complete 2009+ grille also. Headlights, hood, and fenders are the same.
