Command start won't crank when it's cold out, starts with key still
Old Jan 8, 2013 | 10:24 PM
Canadian_EF's Avatar
Default Command start won't crank when it's cold out, starts with key still
Alright so basically when it gets to be -20 or so out, my command start won't work. It's pretty inconvenient. It's a Viper 5901. My parking light flash also stopped flashing.
I've tried re-learning the tach signal, changing from tach signal check to voltage signal check, still nothing. It works just fine when it's a little cold out, or if the engine is warmed up, but not when it gets to be frigid outside.
It doesn't even TRY cranking. Looks like a normal start-up sitting in the car... ignition power comes on, seatbelt chime beeps, then *click* and shuts off. :/
Really annoying. Any sort of help is appreciated.
Old Jan 9, 2013 | 07:17 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Command start won't crank when it's cold out, starts with key still
What is the error code it gives. Sound like low battery or frozen starter.
Old Jan 10, 2013 | 06:28 PM
fcm's Avatar
fcm
Old Fart
As always, my question is where did you get the Viper 5901 from, was it an authorized DEI dealer, or was it a non authotized online site? 94
Old Jan 17, 2013 | 08:18 PM
I bought it locally, new and sealed, from someone who was going to install it but decided it was too daunting to do.
I don't know how to check error codes from the alarm...
Today when I tried starting it, after sitting for a week, it tried cranking and nearly started... it had 2 good cranks, then clickclickclickclick while trying to crank. Started with the key just fine though. :/
If I had extended the wires on the relay, the heavy gauge wires, would that cause an issue? I used the same gauge wire. If that's the case, I'll rip it out and re-do the install...
Old Jan 18, 2013 | 07:01 AM
fcm's Avatar
fcm
Old Fart
I would definatly check the connection(s) of the remote starts starter lead, along with the units ground.
What kind of connections did you make, are they soldered? 94
Old Jan 18, 2013 | 09:09 AM
Yes, soldered, and I made sure the solder flows into the joints. I'm sort of OCD on that...
Winter is almost over anyways and the car is getting an overhaul. I'll update this next winter...
93civicsedan
Audio / Security / Video
Oct 24, 2013 06:14 PM
BAY_99DB8LUV
Apr 2, 2011 07:54 PM
2000integls
Oct 6, 2009 11:14 AM
DIYZane
Mar 5, 2008 10:30 PM
superthug
Oct 29, 2006 05:06 PM
