what oil to use and how many quarts
Old Jan 8, 2013 | 06:29 PM
colts0455's Avatar
Default what oil to use and how many quarts
i know this is a funny quesition to ask but idk what weight of oil to use ive got a stock 1995 honda prelude s 2.2 single cam motor ive always used 10-30 in my mustangs and camaros of past
Old Jan 8, 2013 | 08:49 PM
theBB1er's Avatar
Default Re: what oil to use and how many quarts
10w30 works
I'm guessing yours has F22 motor, I had that in my old accord and remember it recommending 5w30 in a sticker on the underside of the hood.
you'll need 1 gallon
Old Jan 8, 2013 | 10:32 PM
PrePreOwner's Avatar
It should say in your manual if you have it?
Old Jan 9, 2013 | 04:47 AM
schmitty915's Avatar
x2^ Or the sticker under the hood.
Old Jan 9, 2013 | 07:37 AM
Danny Fallas's Avatar
i dont know if there you can get this one, but i used 20w-50 valvoline vr1, and the engine sound and everything changed. Now is running faster! And smoothier!
BTW: We are in Costa Rica!
Old Jan 9, 2013 | 08:24 AM
colts0455's Avatar
yeah it came with no manual sucks ill look under the hood and again thxs for all the info guys
Old Jan 13, 2013 | 06:29 AM
h22god's Avatar
Synthetic castrol 5w30 and a OEM filter can't beat it.
Old Jan 13, 2013 | 05:11 PM
Crxh22ajdm's Avatar
I Use royal purple 5-30
Old Jan 13, 2013 | 07:44 PM
colts0455's Avatar
think im just get castrol high mileage 5w30 at advance for 25 bucks they got a deal goin on with a filter its got 257k going strong so far
Old Jan 14, 2013 | 01:14 AM
Crxh22ajdm's Avatar
Go for Royal Purple, its one of the best oils out there, Better than Mobile1 trust me you will love it
Old Jan 14, 2013 | 01:52 PM
92PurpleLude's Avatar
I like this stuff, just remember to get the Synthetic Titanium Edge. I prefer this stuff to Mobile 1 HP, but Valvoline VR1 is also a respectable choice. Can't say much about Royal Purple, a lot of their oils are syn-blends. All my royal purple buds are now going with Castrol.
Old Jan 14, 2013 | 02:23 PM
h22god's Avatar
And there is many very good reasons why they are. Everyone
Should read there website and about there oil. Castrol is
Used by many pro drag,rally,drifters,NASCAR, and many more
Use castrol on your next oil change people and you will
" Feel the difference " smoother, better acceleration
Just try the stuff once and you will be hooked.
Old Jan 14, 2013 | 06:45 PM
Crxh22ajdm's Avatar
im gonna try it on my neext tune up ^^^
Old Jan 14, 2013 | 07:07 PM
snobordboy's Avatar
Moderator
Guys, the big reason why people run either Royal Purple or Brad Penn oil in Honda engines is for the flat rocker faces of the H22 and H23, due to the added zinc content of the HPS Royal Purple.
As environmental regulations get stricter, many oils have dropped zinc content drastically, but our engines need it to keep the rocker faces and cams happy.
In the F22 engine, it may not such a concern, as I have honestly never looked at an F22 head to see if the rockers are the same.
If the engine is high mileage i.e. over 50-70 K miles, and has run non-syn oils, don't switch to a synthetic, as it will probably caus leaks and damage from seals that are used to regular oil.
On my new builds, I run non-syn for the first 3-500 miles of break in, which I do 2-3 oil changes anyways, then switch to Royal Purple (HPS only).
Old Jan 14, 2013 | 07:48 PM
colts0455's Avatar
yeah ive just got a single cam 2.2 16v motor with 257k miles on it ive used about all types of oils over the years i love castrol high mileage ive used valvoline alot as well never used Royal Purple i really dont wanna spend almost 60bucks on a oil change i could see if i had a vtec with mods but its just simple old single cam im run it till it goes then put a vtec in it all ive used in my higher mileage cars is valvoline hm or castrol hm never had problems thxs for all the post
Old Jan 14, 2013 | 08:04 PM
P. Hunter's Avatar
lol dont listen to the people who are saying to use the expensive oil...
it really is not worth the price
Old Jan 15, 2013 | 07:01 AM
I'm curious about what zinc does for flat rockers, Does it aid in lubrication? If so there should be less resistance, and you should see MPG gains.Trying to be open minded.
My H23 ran conventional for 180k, and I can confirm that an abrupt change to synthetic messes with gaskets because of the different seal swell rates. Even though it took time, I never regret switching to synthetic for its improved life time, performance, and economy. Not to mention the peace of mind associated with all new gaskets! One of my buddies used a Royal Purple synthetic blend oil to ease the gaskets into the new seal swell rates, and he only had to replace a leaky valve cover.
One of my buddys rock crawls using Toyota FJ40's and Jeep Cherokees and he swears my AMsOil. Now I know this stuff is premium, but I've never run into any Honda owners who regularly use it. Am I misinformed, or has no one tried this oil? Check out some specs and drain intervals...
http://www.amsoil.com/shop/by-produc...tic-motor-oil/
Old Jan 15, 2013 | 09:36 AM
friutoftheLude's Avatar
i bought my Lude about a year ago with 98K, switched it from regular to Valvoline full synpower right away, drove it for a few hundred miles, then changed it again early to clean the regular oil gunk, and still runs strong, DID change out my rear main seal, but that was just because i changed my clutch and flywheel, so while i was down there...you know
but i didnt have a problem with the switch......YET (just knocked on wood)
Old Jan 17, 2013 | 10:16 PM
shortdahri's Avatar
5 Quarts - http://www.carcademy.com/1995-honda-...apacity-chart/
5W-30 - http://www.carcademy.com/what-oil-fo...honda-prelude/
Old Jan 17, 2013 | 11:04 PM
Lugzilla's Avatar
Canuckian
I use Royal Purple HPS 5w30 in my '01 lude. Nothing really too spectacular in the way of changes motor ran a little bit smoother compared to other stuff I've used. But the biggest difference I noticed was on cold start ups after sitting in sub zero temps all night; compared to any other oil I've used, RP is by far the the best for this imo. It turns over pretty much instantly and runs nice and smooth.
Pricey though, gotta wait for it to go on sale then I buy a three or four of the 5gal jugs and stash em.
Old Jan 18, 2013 | 03:01 AM
holmesnmanny's Avatar
I just started using Royal Purple 5w-30 in my H22a the last oil change. I have gone 7500 miles and the oil looks dark and I have a mild valve cover leak that I have been just not worrying about but I haven't had to add any oil though it's now at the min mark and I'm going to change it out and send a sample to Blackstone labs. I will update the results when I get em back.
I'm not too sure honestly of how different the ride has been...smoother or not..it does seem smoother but u know that that could be in my head, but I would like to be able to go 7500 miles without having to bother with an oil change and I will just pick up a big 12 quart set from amazon for like $90 or so if the results seem good.
Old Jan 20, 2013 | 10:48 AM
Qluder's Avatar
Definitely 5W-30 during the winter, 10W-30 during the hotter months. Use quality oil and filters, your engine will thank you for the tlc. My H22A4 takes a bit over 5 quarts.
Old Jan 21, 2013 | 05:16 PM
bykfixer's Avatar
5 qts of Castrol high mileage on my last change. K&N wrench off filter. Next time I'll use a puralator but the k&n looks cool. 2.2 vtec
High mileage since my old engine leaks less than the mobil 1 did. And it's less expensive. Same as the purolator.
Royal Purple is fine. So is Mobil 1. Amsoil too. But castrol gets the job done.
Old Jan 30, 2013 | 07:35 PM
nteglude's Avatar
5qt of Pennzoil Ultra 10/30w
Old Sep 6, 2013 | 04:35 PM
Joe@Bisimoto's Avatar
I would definitely suggest Purol 100% pure synthetic oil. It has Shear Stability so it resists being broken down by engine forces. It is a high VI engine oil so it never gets thick in cold weather and also never gets thin in hot weather, it always stays true to its viscosity. It also increases horsepower, while protecting your internals, and improves fuel efficiency.
