6000watt Stereo Set up in 95 Civic Coupe...SWEET!
Thank you. The bass is ridiculous. Turned up beyond 15 it really is honestly hard to focus your vision on anything if you are in the car. haha. The car itself is pretty nasty too. D16 single cam, made 717whp. It should be in Dsport as a feature car in the next 2-3 issues.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
6000 watts or is that a typo and you mean 600 watts? If your title is correct. Ill like to see your charging system please.
this car doesn't add up, obviously not 6000 watts, not 717 RWHP yes RWHP.
http://forums.evolutionm.net/other-c...d16-civic.html
here is another thread about it
http://www.d-series.org/forums/party...treet-car.html
This guy is full of a bucket of you know what! 4 gauge wire! And a autozone crappy battery. hahaha. And a car that makes all of this crazey horsepower with a turbo and exhaust that cant do it.......Get out of here!
The cancellation from from two different size subwoofers is reason enough not to do it. Looks like you got Deadmaus's head mounted to your rear seat too...
Under the hood is a different story....Very nice
I would like to see those dyno sheets, so would our dyno guy, so would my boss who builds 1000HP monster trucks.
As for the 6000W audio system, yea maybe, if struck by lightning.
94
94
The single cam can make some nice power. 600 is doeable. But not with that turbo and 2 inch exhaust.
so they say it made 717 whp with a 6262, yet speedfactory needed a 6765 on 35+ psi on a completely built d16 drag car to make 789 whp, and on the evo forum this guy said they had room to spare, are we to assume a d16 trans can hold all that anyway? ....also this car is supposed to be in a magazine. sounds like they fluffed numbers to get into the mag.
is it just me or do those subs look crooked?
Yeah...the subs are crooked. His dumbass can't even use a damn ruler/level. haha
thats probably like 6000 peak watts, which isnt that ridic. probably around 2000 rms which is easily obtainable. he just added the biggest numbers on his amps together im sure
A 1200W RMS amp would need a 2ga.
The 800W RMS amp could use the 4ga as long as it is not longer then 12 feet.
Even if the 6000W is "peak power" RMS wattage would be around 3000W 6that would still mean at leas two 4ga and maybe a 6ga, you may be able to get away with an 8ga for the high-pass amp.
Like I said ISBL. 94
No kidding, a 4ga cable will handle about 150A of current, you need 160A to produce 1000W RMS, and a 4ga powering a 1000W RMS amp can not be longer then 8 feet.
