JDM Del Sol VXi new owner, and dash light on for overheating cat converter?
Old Jan 8, 2013 | 09:22 AM
novasting's Avatar
Default JDM Del Sol VXi new owner, and dash light on for overheating cat converter?
Hey guys newbie here... I just recently got my first honda, a del sol vxi with 29000 mile on the clock. In great condition. Why ive not had a honda before now no one knows but im loving it. I do however have a problem theres a red light on the dash im led to believe its something to do with the cat temp, being jdm? Is this true? If I join the two wires going to the sensor together this should turn it off? Will this improve my mpg? Im getting 300 miles to a tank does this sound right? Cheers Tom
Last edited by deschlong; Jan 8, 2013 at 12:46 PM. Reason: Clarified topic in title
Old Jan 8, 2013 | 12:29 PM
Former User's Avatar
Default Re: Del Sol VXi new owner, dash light!???
Post a picture of the dash light. Do you mean the CEL? Or the charging system light?
Old Jan 8, 2013 | 12:41 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
No, he means the catalytic converter temp sensor light -- JDM only. I actually have no clue how to interpret it, what the meaning of it is, nor how to fix it. I guess the first question would be: what makes a cat overheat? And work from there.
But, I DO know enough that "joining the two wires together" to turn off the dash light won't make the problem go away. Come on. That's as bad as pulling the bulb out of the cluster when you have a CEL. Problem is NOT fixed. Smarten up. You'll still have the problem, and any low mpg or other consequences that go with it.
Old Jan 8, 2013 | 12:51 PM
Default Re: JDM Del Sol VXi new owner, and dash light on for overheating cat converter?
The cat overheats when the engine is running way too rich. Unburnt fuel in the exhaust ignites and burns in the cat. This is usually caused by engine misfiring, high fuel pressure, exhaust leak, stuck open injector, etc.
Old Jan 8, 2013 | 02:20 PM
novasting's Avatar
Ok cheers for the replies so far. I shall try posting a pic tomorrow im hopefully getting it plugged in on diagnostics machine at college soon and hopefully that'll enlighten the situation. Although being a jap import im not holding my breath. Would the light have come on if I decat it too then? Cheers Tom
girlscandothis
Honda CR-V & Element
Jun 3, 2019 09:14 PM
drgtr
27
Dec 27, 2010 11:01 AM
So FReSh
Oct 9, 2008 12:29 PM
verity
Aug 31, 2008 06:21 PM
Consure
Feb 10, 2002 07:01 PM
