Kelford vs. Drag Cartel CIC (K20A2)
i will upgrade the cams (only) in my K20A2 engine and found 2 very good cams:
Kelford 179A and Drag Cartel DIC
which one is the best for daily drive....on stock engine with following mods:
RBC IM incl. bigger 64mm TB
Toda header with 200cell cat
OEM JDM EP3 exhaust system
Big Carbon Airbox incl. ram-air
K-Pro
ATi dampr
which one make the best power, which one the best torque,....?
which one is the best allrounder?
thanks for help!
K-Pro
ATi dampr
thanks for help!
Both have been known to be very DD friendly and both have been covered by many people.
Import Tuner Article.
http://www.importtuner.com/tech/impp...a/viewall.html
Drag Cartel DIC's test (Thanks Katman!)
http://www.k20a.org/forum/showpost.p...&postcount=566
Please note that there are a lot of variances between the DCs and Kelfords in terms of platforms and bolt ons involved during the dyno process.
We have have good results out of both cams. Both are very nice and DD friendly. You will get a different result as far as dyno with every car. So its hard to say what your car will put down.
