cigarette lighter not working 94 gsr (it's not the fuse)
Old Jan 7, 2013 | 02:59 PM
B_Swapped93's Avatar
Icon2 cigarette lighter not working 94 gsr (it's not the fuse)
it's really annyoing not being able to use my GPS. i've had this problem since i got the car back in october. it's not the fuse i don't know if theres a relay somewhere, if there is could someone tell me where ?
thx
Old Jan 7, 2013 | 03:08 PM
JuicedUpRice's Avatar
Default Re: cigarette lighter not working 94 gsr (it's not the fuse)
Start by checking for 12v at the CIG lighter wires.if you dont,trace it back,or ask for more help from there.
Old Jan 7, 2013 | 03:29 PM
fcm's Avatar
fcm
Old Fart
There is no relay, as mentioned, test for power at the ligher lead plug.
Does your radio work, same fuse? 94
Old Jan 7, 2013 | 05:54 PM
yes radio works just fine. i'll need to get a voltmeter right ?(to test the wires)
Old Jan 7, 2013 | 06:16 PM
mechanix619's Avatar
The ground or power wire probably came loose.
Remove the ash tray to expose two screws and you can pull the assembly out.
Stephen122193
Jul 11, 2015 06:07 PM
undisputed803
Audio / Security / Video
Jun 5, 2010 07:11 PM
AcInTheEg
May 2, 2007 04:05 AM
pinkspider
Oct 23, 2006 02:11 PM
mars
Jan 24, 2006 02:46 PM
