honda civic 1998 hatch keyless entry
hi guys i just bought a keyless entry and i cant installed i need some help my keyless is with 10 pin has ....pink,black,red,purple that separate in tow purple,yellow/black,yellow,green,blue,brown,gray.
1998 Honda Civic Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Yellow Ignition Switch Harness
Accessory White/Black Ignition Switch Harness
Tach Blue Coil
Neutral Safety Wire Black/Blue (-)
Brake Switch Green/White Brake Switch
Trunk Pin Blue/Black (-) Driver's Kick or behind Radio Light Green (-)
Parking Lights Red/Black Driver's Kick Panel or above Fuse Panel
Head Lamp Red/White left. Red/Blue right at Steering Column
Door Trigger Light Green/Red (-) Anti-Theft Module behind Radio Green Connector
Door Lock Green/White (-) Above Fuse Panel or at Anti-Theft Module
Door Unlock Green/Orange (-) Behind Radio Green Connector
Driver's Lock White/Red Driver's Door
Driver's Unlock Blue/Red Driver's Door
Passenger Unlock Yellow/Red Passenger's Door
Horn Wire Blue/Green (-) Steering Column or Green Connector behind Radio
Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green
Tach Blue Coil
hentai_11
Audio / Security / Video
Jul 20, 2009 08:03 PM
dafuzzbudd
13
Oct 4, 2008 03:52 PM
