Wire tuck/Intermittent Electrical/Main relay
Old Jan 6, 2013 | 04:54 PM
xero_xero's Avatar
Default Wire tuck/Intermittent Electrical/Main relay
I will go through and add pictures for this, and it may take some more experianced electrical gurus.
1995 Honda Civic Cx
Fresh wire tuck, nothing was cut other than grounds in the engine bay on the white 8 plug ground terminals.
On the main relay, i get no power to the fuel pump to prime.
the t stat housing ground is connected.
relay unplugged
i have continuity to the fuel relay ground.
Green/Yellow no power to the pump
Yellow/White 12v battery supply is there
Yellow/Black (ecu power) 11.4v
yellow/Green -.51v (black to ground)
Black/yellow 11.4v (II)
Blue/White Ignition Switch -.51v (I) and 8v(II)
Ignition Switch
White 12vconstant
black white starter 12v start
black yelow 12v run start
white black 12v run
yellow I and II
Old Jan 6, 2013 | 05:01 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Wiretuck/Intermitten Electrical/Main relay
How were the grounds reconnected? Soldered and shrink wrapped?
Old Jan 7, 2013 | 12:41 AM
xero_xero's Avatar
The grounds themselves were ran through thefender. Ends were cut off and attached to butt style ring connectors.
Old Jan 8, 2013 | 03:37 AM
xero_xero's Avatar
Checked all grounds for contunuity to the frame. All xhecked good. Next going to check every power and ground to the ecu
Old Jan 8, 2013 | 04:57 AM
d15bvtechatch's Avatar
is it a fuel pump prime delay? if so, it could be capacitor 14 in your ecu, this is a common issue
http://www.hondata.com/tech_capacitor_obd1.html
https://honda-tech.com/forums/engine-management-tuning-124/chipped-p28-not-priming-fuel-pump-1159611/
Old Jan 8, 2013 | 07:35 AM
xero_xero's Avatar
Both relay anf ecu tested in my teg. Tested fine.
Old Jan 8, 2013 | 07:55 AM
EsotericImage's Avatar
Retired Moderator
Its issues like this that make me rethink attempting to do a tuck
Old Jan 8, 2013 | 09:21 AM
Former User's Avatar
Originally Posted by xero_xero
relay unplugged...
The Grn/Yel wire cannot get voltage if the relay is unplugged. Redo the voltage test at the fuel pump with the relay plugged in. Use the fuel pump connector Blk wire as ground and compare the voltage reading when using the chassis as ground.
Old Jan 10, 2013 | 03:50 AM
xero_xero's Avatar
Ok.
Looking for the service tech manual at the moment.
Does anyone have any pdf that are not scans?
Old Jan 10, 2013 | 06:23 AM
Should be easy to find with a Google search.
Old Jan 11, 2013 | 02:47 PM
xero_xero's Avatar
Default Re: Wire tuck/Intermittent Electrical/Main relay
just rechecked everything. have continuity to the ecu grounds and chassis.
i get 9.5v from the blu/whi on start only, not run.
0v to fuel pump chassis ground and fuel pump ground
i checked the jumper harness that i made to do the wire tuck, and every terminal end matches.
and the next step is to undo the engine hanress and plug it strait.
ill post up pics in about 15.
Old Jan 21, 2013 | 03:33 PM
xero_xero's Avatar
neglected ground.
after hours of tearing apart everything, i checked voltage at the chassis and on the physical grounds.
broken ground wire off of the curent car i am driving.
on harness, nearly impossible to find. pulled 5 volts when 12 was there.
ganjasnack
Dec 23, 2024 12:17 PM
Chinamandrift
Audio / Security / Video
19
Jun 13, 2012 10:39 AM
mongoliandonuts
Jun 14, 2004 09:22 AM
BoostedH23a1
Nov 3, 2002 07:12 AM
