needahelp; sedan ef 89 lx, havin a hard time to change shift...
Old Jan 6, 2013 | 02:21 PM
jdmISmyGOD's Avatar
Default needahelp; sedan ef 89 lx, havin a hard time to change shift...
hey, right now my car is 89 sedan lx and when i drive, im havin a hard time to change a shift on first gear n 2 n 3 so whats wrong with it? it sounds kinda of dry so is it the fluid ? please lmk n needs this info asap....
Old Jan 6, 2013 | 02:35 PM
1991civiclx13's Avatar
Default Re: needahelp; sedan ef 89 lx, havin a hard time to change shift...
try adjusting your clutch cable
Old Jan 6, 2013 | 04:39 PM
mpt.ed3's Avatar
try short turns and check after each adjustment.
Old Jan 6, 2013 | 06:56 PM
jakkeduphonda's Avatar
hope I don't run into any problems with my swap !!! good luck tho
Old Jan 7, 2013 | 08:19 AM
jdmISmyGOD's Avatar
it have nothing to do with the clutch bec its brand new cable adjustment line but when i turn into the gear n it sounds grind...kinda of dry fluid in it so what best fluid should i get, the lube lucas 15w-40? idk which one to get
Old Jan 7, 2013 | 08:20 AM
honda MTF
Old Jan 7, 2013 | 10:22 AM
GPC91's Avatar
10w30 or 10w40 conventional works also it says in the manual i believe. but i would change it more than if you used the actual mtf.
SobrietyRulesNA
Transmission & Drivetrain
Jun 20, 2013 08:18 PM
kris9
Apr 10, 2010 02:46 PM
91civicracer
Mar 29, 2009 06:09 PM
jlkinkona
Dec 28, 2007 02:57 PM
meangreenEG
32
Jun 28, 2007 11:09 PM
