91 accord not starting
Old Jan 6, 2013 | 12:55 PM
jmar4life's Avatar
Default 91 accord not starting
hi, new to the forums and in need of some help. i have a 91 honda accord that was running fine until the 1st of january. it would crank but wouldnt turn over. a few days later i go to try again and the battery is dead. nothing was left on. i put a new battery in and tried turning on the car again but its not starting still. it also appears that the battery is draining pretty fast. any suggestions on how i can fix this?
Old Jan 6, 2013 | 01:02 PM
92 civic ex 4dr's Avatar
Well. First check to make sure you are getting air, fuel, spark, and compression. Check the air filter, cap, rotor, plugs, wires, fuel filter and even check the fuel pump. About the battery drain. A test light and a second person with the ignition off will help you to identify and isolate the source of the drain.
Posted from Honda-tech.com App for Android
Old Jan 6, 2013 | 01:05 PM
jmar4life's Avatar
Default Re: 91 accord not starting
well im kinda new to this whole diy thing, so is there a faq or could you walk me through how to do all that?
Old Jan 6, 2013 | 01:17 PM
j-gonzo-a's Avatar
We all where in your same position it helps to look online just litterly Google search anything it might be and check it anything you think you can do. If worse comes to worse im sure they'll have some videos on YouTube just try not to mess up your car more lol
lthsmokey
Classic Hondas
Oct 5, 2015 02:05 PM
cjmguitarist87
Oct 23, 2011 06:30 PM
kc2mrg
Jun 1, 2011 07:59 AM
2ndgentegracer
Aug 29, 2004 06:52 PM
