engine codes for zc
Do you mean engine, ecu codes?
Code 0 _____ Faulty ECU
Code 1 _____ Oxygen content
Code 2 _____ Does not appear to exist
Code 3 _____ MAP sensor
Code 4 _____ Crank angle sensor
Code 5 _____ MAP sensor again
Code 6 _____ Coolant temperature
Code 7 _____ Throttle angle
Code 8 _____ Top dead center sensor
Code 9 _____ No. 1 cylinder position (only on 1.6L)
Code 10 ____ Intake air temperature
Code 11 ____ Does not appear to exist
Code 12 ____ Exhaust gas recirculation system
Code 13 ____ Atmosphric Pressure
Code 14 ____ Electronic air control (EACV)
Code 15 ____ Ignition output signal
Code 16 ____ Fuel injector
Code 17 ____ Vehicle speed sensor
Code 18 ____ Does not appear to exist
Code 19 ____ Lock up control solenoid (auto trans only)
Code 20 ____ Electric load
(from crxsi.com http://www.crxsi.com/resources/manual/ecu_codes.htm)
otherwise, the block codes are these.
d16a8
d16a9
ZC
d16a8
d16a9
ZC
vtc-gn2
Mar 29, 2005 07:01 PM
