sunroof odor
Old Jan 5, 2013 | 04:25 PM
tangoalpha's Avatar
Default sunroof odor
Hi I am a new user looking for some advice/help. I own a 2002 Accord 4dr SE automatic. This winter I've discovered there's a unpleasant coming from the sunroof area. When I look into the sunroof area i see condensation on the metal. Is this a known issue? How do I remove the odor? Thanks in advance.
Old Jan 5, 2013 | 07:33 PM
jdowen2's Avatar
Default Re: sunroof odor
Drain tubes are probably partially or fully clogged. Pour a little white vinegar around the perimeter of the open sunroof. That should help to kill the odor. Use CLR liquid to hopefully open the drains.
Old Jan 5, 2013 | 07:37 PM
v4lu3s's Avatar
RTFM
i have a crx with a sunroof and i actually had to separate the drain tubes at the ends to clear out "mud" that was clogging them.
Old Jan 5, 2013 | 09:24 PM
tangoalpha's Avatar
where are these drain tubes located?
Old Jan 5, 2013 | 09:31 PM
tangoalpha's Avatar
cant wait til the morning so I can try this out
Old Jan 5, 2013 | 10:13 PM
jdowen2's Avatar
To get to the drain tubes you have to remove the moonroof window.
mike001
May 17, 2006 04:47 AM
kgard
Dec 8, 2005 01:47 PM
athoughts
Nov 28, 2005 04:47 PM
sho
Aug 23, 2003 09:54 PM
travis
Apr 11, 2002 09:22 PM
