What's the best stuff to use to get the paint off a valve cover?
Old Oct 20, 2002 | 07:47 AM
E Swift's Avatar
Default What's the best stuff to use to get the paint off a valve cover?
I want to strip whatever paint is left on my valve cover off, so that I can repaint it, and I remember a while back, somebody was saying that there's some stuff you can buy that takes it off. But I don't remember the name, so does anybody know what to use?
Old Oct 20, 2002 | 07:50 AM
Blown90hatcH's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (E Swift)
Get some airplane stripper. That stuff works wonders.
[Modified by Blown90hatcH, 8:50 AM 10/20/2002]
Old Oct 20, 2002 | 07:53 AM
E Swift's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (Blown90hatcH)
Where can I buy that?
Old Oct 20, 2002 | 08:16 AM
M.A.R.C.'s Avatar
i think it's called aircraft stripper or something. i saw it at discount auto parts, but it was outta stock. most auto stores like that should have it
Old Oct 20, 2002 | 08:35 AM
boomslang's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (CivicRyda2k)
Yeah, use some aircraft stripper. Just give it plenty of time to work. You can buy it in an aerosol can at Autozone.
Old Oct 20, 2002 | 08:56 AM
moyerek's Avatar
def use airplane stripper, you can buy it at Wal-Mart. You might have to do a few applications to get all the paint off and make sure you rinse it off really well when finished and wash it down with soapy water to neutralize any left over chemicals.
Old Oct 20, 2002 | 09:02 AM
Mase's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (moyerek)
i thought it was called aircraft remover
Old Oct 20, 2002 | 09:07 AM
Quaalude's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (Mase)
it is...you can buy it at any autoparts store...don't forget to get some thick chemical resistant gloves because that **** burns if it gets on your skin
[Modified by Quaalude, 1:08 PM 10/20/2002]
Old Oct 20, 2002 | 10:31 AM
dustin's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (Quaalude)
Yeah that stuff REALLY stings if you get it on bare skin. Even if you only get the smallest dot of it... ouch.....
Old Oct 20, 2002 | 10:46 AM
I Like Boost's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (dustin)
its called aircraft paint remover, spray it down with that and wear gloves. it will start bubbling off the paint and use some type of brush to scrape it off with. when its all down remember to hose it off than primer it than paint.
Old Oct 20, 2002 | 10:49 AM
B18EG6's Avatar
Default Re: What's the best stuff to use to get the paint off a valve cover? (BEe18SeAONe)
i used a sandblaster, worked like a charm...
4twenty_CRX
32
Jul 17, 2007 09:34 PM
compint
Nov 6, 2006 11:43 AM
steve9927
Apr 22, 2004 10:23 AM
civicsport
Jul 17, 2002 07:04 AM
customx_
Mar 7, 2002 05:23 AM
