pass. and both rear windows wont roll up o down
I have a 2005 Honda Accord. The drivers side window will roll up and down perfectly fine but when trying to roll any of the other windows up or down from drivers side switch they won't move but instead make a clicking sound. When tryin to roll them up from any other switch it doesn't make the clicking noise. I am broke and can't replace parts, but two of the windows are stuck down and won't roll up. I just want to be able to roll the windows up and leave them. Is there any way I can do that. Thanks for the help.
The motors are prolly screwed up....anyways, Try removing the side panels from the doors, you should have easier access to the windows. Then just lift the windows up.
yea lifting the window wld be good but the regulator wont follow the window your going to have to wedge it up with something sounds like the window regulator\motors are froze up u can try smacking the motors wile flicking the switch to get the windows up for now
si-ej1
Apr 4, 2012 05:30 PM
Thrillhouse
Nov 9, 2003 07:19 PM
