94 & up f22 in a 91 Accord
Old Jan 4, 2013 | 01:29 PM
invader_zim's Avatar
Default 94 & up f22 in a 91 Accord
So my Accord wagon blew its engine and I need to know if I can use a newer engine in my older car and what will need to be done if anything. I am thinking that the Accords didn't go into OBD2 till 95 but I am not certain. Thanks in advance for any help.
Brian
Old Jan 4, 2013 | 01:44 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94 & up f22 in a 91 Accord
Brian
'94/'95 same. '96/'97 are OBDII and different, but can be made to work.
Old Jan 4, 2013 | 02:13 PM
So what would I need to do to make a 96/97 engine work in my car? The only reason I ask is that it seems the newer engines are cheaper and have lower mileage than the engines from my generation.
Old Jan 4, 2013 | 04:05 PM
MAD_MIKE's Avatar
MM Gruppe B
My bad should have said the difference.
96/97 uses a different distributor and the crank sensor is on the crankshaft.
IIRC All you need to do to install a 96/97 B1 into a 94/95 is install all the 94/95 bits and ignore the crank sensor pigtail.
Old Jan 4, 2013 | 04:30 PM
So it should be the same to put it in a 91 correct? And that you for answering my questions.
Old Jan 7, 2013 | 11:08 PM
MAD_MIKE's Avatar
MM Gruppe B
Sorry, not sure of all the details of putting a B1 into a CB. However, if the B1 has already been swapped in, then it would be like working on a 94/95. And yes, reuse all the 94/95 B1 parts, and ignore the 96/97 B1s crank sensor.
64waves
May 28, 2016 10:14 AM
hari2m
Oct 17, 2014 03:33 PM
95halx
Nov 8, 2012 04:38 AM
AccordCD5
Mar 13, 2004 12:05 PM
accord2doorbaby
Apr 28, 2003 05:13 PM
