Ek 96 hatch y8 head z6 block idles
Old Jan 4, 2013 | 05:58 AM
TexMexOG's Avatar
Icon2 Ek 96 hatch y8 head z6 block idles
I just got my swap built by a friend z6 block y8 head high comp pistons y5 intake manifold and wire harness, got all gaskets no leak but it idles high and then drops and back up high an drops constantly , thinking it could be ecu? Or intake manifold since y5 is vtec-e?
Old Jan 4, 2013 | 06:00 AM
Emeraldbomber's Avatar
Default Re: Ek 96 hatch y8 head z6 block idles
Do you mean the idle is surging constantly?
Old Jan 4, 2013 | 06:35 AM
HondaPartsHero's Avatar
Technical Hero
What ECU? Any check engine lights?
Old Jan 4, 2013 | 07:03 AM
69NOSAJ's Avatar
sounds like common vacume leak or TPS
Old Jan 4, 2013 | 09:05 AM
TexMexOG's Avatar
If surging I the word, yes, ecu doesn't have code but i think its y5 ecu we tried putting a p28 and it started going crazier same with p2p ecu, thinking of putting y8 intake mani and y8 harness,instead of y5 ..
Old Jan 7, 2013 | 07:20 PM
TexMexOG's Avatar
Old Jan 7, 2013 | 07:21 PM
TexMexOG's Avatar
in small part you can hear it rise and drop rise and drop, and then its drowed out by my friend messing wit it thinking it might be the iacv
TexMexOG's Avatar
HELP!!!!!!!!!! lol
Old Jan 7, 2013 | 07:43 PM
NateCr3's Avatar
if you put your finger over the valve cover breather hole it idles normal?? thats what it looks like in video
Old Jan 7, 2013 | 07:52 PM
NateCr3's Avatar
If thats true you have a vac leak into crankcase. I see you have a clear hose from pcv to intake mani. make you you have pcv installed or that its not bad. only thing i can think that would cause a vac leak into crankcase.
Old Jan 19, 2013 | 04:32 PM
TexMexOG's Avatar
i put the y8 intake mani, and it revs up HIGH {straight} i switch the y5? ecu and put the p2p y8 ecu and it goes back to reving up and down.....WTF
Ekevans08
Dec 12, 2012 06:11 AM
SHG_Beans
Jun 19, 2006 04:55 AM
SOHC_MShue
Oct 13, 2003 07:28 PM
