96 Integra wiring questions
Who the fack changed my title?!
ok so as i was backing up and repositioning my car to go back up into its new parking spot, the bumper lights were accidentally hanging and got ran over. can anyone be kind enough to provide the color specifications for the following:
driver high/low beam wiring color schematics
driver daytime running light/turn signal wiring color schematics
i would greatly appreciate it if anyone could help me out. because this has happened, im also experiencing a random *** surge in the idle right after this happened. so hopefully this will correct all the problems im having.
Drivers high beam is red/green low is red/yellow, DRL is red/green to the high beam, [red/green], but it should not be at the head light, it will be farther back up the line.
Drivers signal/park light, [bumper light] signal is green/blue and park is red/black, drivers front side marker green/white. 94
is the drivers front signal the same as the signal light? you mentioned 3 lights, i believe i only have 2 in the actual light housing
The "signal light" housing has two bulbs, the inside one is a duel filament bulb, one filament is for park lights, the other is for signal lights, the outside one, [front side marker] is a single filament bulb and it is both park and signal light, [controlled by the ICU].
Well I converted to the 98/00 front, and the actual lens has only 2 sockets where you can plug in the bulbs. I was referring to the side marker on the fender.
OIC, the inside "socket" in the lens, is for the dual filament bulb, one filament is park lights, the other is signal lights, the outside socket, is foe a single filament bulb and is also for park and signal lights, but it is controled by the ICU, it flashes the bulb ON for signal lights, [and hazard lights] turns on the bulb for park lights, and flashes the bulb OFF for signal and hazards if the park are on. 94
