i have oil in my radiator what to do
Whats a valve pan gasket?
Also, if there is tranny fluid in your radiator then there is likely coolant in your transmission and you should stop driving immediately, flush the trans and get a new radiator.
its a standard not an automatic so its not tranny fluid... i was thinkin the same thing on changing everything i could just have limited funds at the moment
Then its your headgasket, a crack, or something is connected wrong. Changing the timing kit etc. would be age/mileage dependant or based on visual inspection of the belt.
ujhonda
May 28, 2006 08:16 PM
