Power draw
Old Jan 1, 2013 | 06:17 PM
PhantomEJ1's Avatar
Default Power draw
My 95 civic has a weird problem. Only while driving and at night with my headlights on the dash lights will flicker and when happens the blower motor doesn't blow at 100%. It feels like the engine loses power too. After I drive the car for 45 min. and it's all warmed up its fine. But if I stop somewhere and turn the car off then start it back up the flickering and power surges start up again. I know it's not the alt. I've put 3 different ones on and it didn't change the problem. Any help would be great.
Old Jan 1, 2013 | 09:06 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Power draw
sounds like wiring
if your not the original owner, check to see if wiring looks like OEM or is it a mess.
if its a mess, then start looking
Old Jan 2, 2013 | 10:13 AM
PhantomEJ1's Avatar
Well no ****! I think I'm just going to have to pull every single piece of wire out of these freakin car cuz I just don't know where to start.
Old Jan 2, 2013 | 11:10 AM
Emeraldbomber's Avatar
Easy man, were just trying to help you out.
Old Jan 2, 2013 | 01:11 PM
angrysmileyface's Avatar
Make sure all your grounds are tight and clean.
Old Jan 2, 2013 | 02:11 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Agreed - start with this since you've eliminated your battery and alt. There are a bunch of grounds in the engine bay (at least 3 if not more) and cause no end of problems if they become excessively dirty or the wires are frayed.
Old Jan 4, 2013 | 04:47 AM
PhantomEJ1's Avatar
I got on All Data and printed off the schematics for the grounds and went through all of them and grinded down to metal and reattached and still have the same problem. So now that I know all the grounds on the car are good now what??????
Old Jan 4, 2013 | 04:56 AM
Does the 5thgens have the ELD or is that a 6thGen thing?
Old Jan 4, 2013 | 05:28 AM
PhantomEJ1's Avatar
What is ELD?
Old Jan 4, 2013 | 05:39 AM
Electrical load detector. Same for 5th gen. Just under everything
http://www.civicforums.com/forums/21...-detector.html
Old Jan 4, 2013 | 07:23 AM
PhantomEJ1's Avatar
I don't think I have that and even if I did I don't think that's the problem. Next....
Old Jan 4, 2013 | 07:34 AM
grumblemarc's Avatar
The Grumpiest
Knows what the problem is NOT. Doesn't know what the problem IS. Can't explain that.
Test battery? Never saw that mentioned. Recent occurrence? Running any amplifiers for a sound system? Crappy HIDs installed?
Old Jan 4, 2013 | 07:40 AM
Former User's Avatar
Does the charging system light in the cluster turn on when the problem happens?
Old Jan 4, 2013 | 09:07 AM
PhantomEJ1's Avatar
Battery tests 12.8 and 473/500 cca
Have tried 3 alternators. Yes I have a small amp and some xyntec hids and depo fogs. No battery lights come on.
Old Jan 4, 2013 | 09:18 AM
deschlong's Avatar
Loved
Community Favorite
Unplug HIDs during the DAYTIME, drive it around with the headlight switch ON. Deactivate them completely -- as in, make sure the ballast is not getting any power either (and if there's anything else that gets power that goes along with having HIDs ... don't know much about them other than they often suck). Still have the problem? (Trying here to eliminate HIDs as the mystery power drain.)
Also, when did this problem start? Was it after a specific event (eg., giant pothole, epic rainstorm) or mod?
Old Jan 4, 2013 | 10:25 AM
When you turn the key from off to ON(II), does the charging system light come on and stay on?
Old Jan 4, 2013 | 10:46 AM
deschlong's Avatar
Loved
Community Favorite
Is the alternator belt tension within spec?
Old Jan 4, 2013 | 01:58 PM
PhantomEJ1's Avatar
So I started to unplug the hids and found the drivers side factory headlight bulb socket was so corroded it crumbed to a black gooy substance so off to the junkyard in the morning. Even with the hids unplugged the car still has the problem.
Old Jan 7, 2013 | 03:56 AM
PhantomEJ1's Avatar
To answer the other questions yes my charging light stays on after keying the car on 2 clicks. Yes the belt it to spec. Went to best buy today to have look at my alarm and one of the harness's is damaged. The wires are frayed and one is not even connected anymore so ill have to get another harness and see if that's the problem.
Old Jan 7, 2013 | 06:33 PM
PhantomEJ1's Avatar
Installed a new antenna harness and I still have the problem.
Old Jan 7, 2013 | 06:50 PM
NateCr3's Avatar
Kinda sounds like an ELD problem- So like all the lights flicker??? Headlights, dashlights, even dome light?? The eld changes alt output for loads.
Old Jan 7, 2013 | 10:20 PM
Psychoteen101's Avatar
Lights flickering usually means a diode going bad in the alternator. You said you tried 3 different alternators, were they new or used? If used, have the current alternator tested.
Old Jan 7, 2013 | 11:20 PM
hwyix's Avatar
Where did you get your alternator from? Pep boys/napa/auto zone have crap alternators. The shop next to mine used to go through a lot of those.
Old Jan 8, 2013 | 07:33 AM
PhantomEJ1's Avatar
Does my car even have a ELD? As for the alternators: the original one burned up so I got a Napa one and used it then thought it was bad it tested good but I made Napa give a brand new one. Hooked it up and still had the problem so I took it off and put a used Honda one on and tested it and it tested fine but still have the problem. I'm keeping the Honda one there cuz I trust it more than any aftermarket one.
Old Jan 8, 2013 | 03:34 PM
NateCr3's Avatar
Yeh you have an eld its in underhood fuse box. It a brown squared shaped piece inside. Before you test the eld or replace it if you have a multimeter just connect it to battery and watch the voltage when the problem Is happening. If voltage is fluctuating alot when problem occurs then id test eld. Id kinda doubt you had 3 bad alt.
